TwinTurbo.NET: Nissan 300ZX forum - 1) Check your base timing. 2) Check for boost leaks
Subject 1) Check your base timing. 2) Check for boost leaks
Posted by Ash's Z on March 13, 2010 at 8:41 PM
  This message has been viewed 151 times.
In Reply To low idle posted by mlewis300 on March 13, 2010 at 08:18 PM
Message 3) Make sure your plugs are gapped to 0.035" AND that you are using the corrent PFR6B-11B (with the B on the end). If it doesn't have the B on the end, it is not the projected tip plug that must be used in the TT.
4) If all is well, you can open the idle screw a bit to bring your idle up to ~850. Open it about a 1/4 turn at a time and give a few seconds from turn to turn so that the idle will stabilize.
[ ashspecz.com ]
[ agpowers@bellsouth.net ]
Enthusiasts soon understand each other. --W. Irving.
Are you an enthusiast?
If you are out to describe the truth, leave elegance to the tailor.
Albert Einstein
